cant get it to work for socks - Localtonet Community
0
i put the socks in the args of the application but it doesnt seem to work
Comments (5)
wow1 Apr 26, 2025
how do i get both http and sock5 proxies to work on a single device without creating 2tunnels? i want it to be on 1 tunnel
Localtonet Support Apr 27, 2025
Unfortunately, it cannot be opened at the same time, you need to create 2 tunnels.
wow1 Apr 27, 2025
how do i get the same sock5 and http connection on the same port and connection? why do competitors work and you not?
Resolved
These operations introduce latency, as it requires reading the incoming data each time. For a faster and more stable service, we do not monitor or support this approach.
wow1 Apr 27, 2025
can you check my mail from nathangemieee@gmail.com i like to have a solution for osrs botting which both uses sock5 and http
