1
Getting Started
LocaltoNet first tunnel for localhost site, which type and local address do I use
I just installed it and the UI isn't obvious. The site works in my browser on my computer, but only on localhost, and I want to open it from my phone with Wi-Fi off to confirm it's actually public.
What do I put in for the local address, literally localhost:port or 127.0.0.1:port, and which tunnel type is the basic one for a normal web app? Also where does LocaltoNet show the public URL after it starts, and what's the fastest sanity check that the tunnel is really working end to end?
Comments (5)
Use an HTTP tunnel first, and point it at the exact local thing that already opens in your browser, usually
127.0.0.1:3000orlocalhost:3000with whatever port your app is on. The main gotcha for me was the port, not the host name, so if your app is actually on 5173 or 8000 and you put 3000, the tunnel "works" but shows the wrong thing.Yep, and one extra gotcha is binding. If your dev server is listening only on a specific interface, try switching it to
0.0.0.0in the app config if the tunnel page comes up blank or errors, I've hit that with Vite before.For verification, I usually check the public URL in a private tab first, then test on phone data so I know I'm not accidentally seeing a cached local result.
Turn off your phone Wi-Fi and open the exact public URL LocaltoNet shows in the tunnel list or details pane, that is the only check I trust for first-time setup. Browser tabs on the same PC can mislead you, but a phone on cellular will tell you immediately whether the tunnel is actually reachable from outside.
Open the public URL from your phone in a normal tab and do one tiny change on the page first, like add a weird word to the title or body, so you instantly know you're seeing your machine through the tunnel and not some old page. I've had that save me a bunch when the page "loaded fine" but I wasn't actually looking at the current local app.
That little page edit test is such a good call, I started doing that after moving over and getting fooled by a stale tab more than once. One more easy check is to watch your app logs while you load it from cellular, if you see a fresh request hit at the same moment, you're probably pointed at the right thing.
Please log in to post a comment.
